Network switch Tacacs accounting issue on CPPM
  • 1.  Network switch Tacacs accounting issue on CPPM
    Posted Jun 13, 2017 08:44 PM
    We have configured tacacs on Nortel 4550 switch.
    If we insert “Tacacs authorization level all” command on switch, We were able to get detail accounting log on CPPM
    But same time I got “your command was not authorized”  message on Nortel switch while entering any command.
    Please find attachment for configuration and accounting log
    Thank you..
    Attachment(s)
  • 2.  RE: Network switch Tacacs accounting issue on CPPM
    Posted Jun 13, 2017 08:55 PM
    Are you trying to set up TACACS+ accounting or command authorization?
  • 3.  RE: Network switch Tacacs accounting issue on CPPM
    Posted Jun 13, 2017 09:07 PM
    I want to know which command has used by user on network switches.
    Using tacacs or radius.
  • 4.  RE: Network switch Tacacs accounting issue on CPPM
    Posted Jun 13, 2017 09:10 PM
    Please post your switch config.
  • 5.  RE: Network switch Tacacs accounting issue on CPPM
    Posted Jun 13, 2017 09:17 PM
    Switch configuration is same as below
  • 6.  RE: Network switch Tacacs accounting issue on CPPM
    Posted Jun 13, 2017 09:24 PM
    On the commands tab, check "Enable to permit unmatched commands".
  • 7.  RE: Network switch Tacacs accounting issue on CPPM
    Posted Jun 15, 2017 09:20 AM
    Hi Cappali,
    Could you please share commands which are used in Enforcement profile for Tacacs+
    Thank you
  • 8.  RE: Network switch Tacacs accounting issue on CPPM
    Posted Jun 15, 2017 09:37 AM
    As previously mentioned, all you need is:
