New AP105's keep rebooting
  • 1.  New AP105's keep rebooting
    Posted Aug 15, 2013 05:02 AM
    Hi all,
    We recently received 13 new AP105's, but they all keep rebooting and don't show up in our W-3400 controller.
    We already have 39 other AP105's that work without any problems, but when i connect any "new" AP105 to an existing PoE connection, it keeps rebooting.
    I've attached the logfiles of the new rebooting AP and an existing working AP.
    Can somebody please help me out with this problem?
    Thanks in advance, kind regards.
    Jeroen
    Attachment(s)
  • 2.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 05:29 AM
    You need to paste in the output of "show log system 50" on the controller while that is happening to get a better picture.
  • 3.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 05:36 AM
    Can you please explain to me how to do that? I'm sorry i'm new to troubleshooting the controller.
  • 4.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 05:37 AM
    You have to SSH into the controller and get into enable mode before executing "show log system 50"
  • 5.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 06:44 AM
    I've included the logfile in the attachment, hope it helps...
    Thanks, Jeroen
  • 6.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 09:56 AM
    • Did u check your AP-license? PEFNG-license?
    • Are u working with control-plance security?
    • You sure that no one use the address that been alocated to those ap's from the DHCP?
  • 7.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 10:06 AM
    • I have 15 free AP and PEF licenses, these are newly activated in our W3400.
    • I'm not working with control-plance security
    • The IP adresses are unique in our network, no other appliances are using these IP's.
  • 8.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 10:15 AM
    OK.
    Take a look on this:
    http://community.arubanetworks.com/t5/802-11n-and-802-11ac-Basics-RF/AP-105-sendbytes-error-bailout/td-p/65798
    but before u doing it - just try to take one unit that is failing - connect console - stop in the begning (with enter key) and write
    purge
    clear os
    saveenv
    boot
    and then let it boot and get the AOS - and check if it's up with no problems..i
  • 9.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 10:29 AM
    OK, i did what u asked, but i still have the same problem...
    In the attachment is the log.
    Thanks for the reply btw.
    Attachment(s)
  • 10.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 10:40 AM
    OK.it's was worth a shoot :) as written in the previous post
    Output from the AP: error -bailout indicate a hardware failure moreover the AP  is not completing the boot process. We have process RMA for the APs.
    With the same ap output,I recommend you to open a TAC.
    Regards.
    Me
  • 11.  RE: New AP105's keep rebooting
    Posted Aug 15, 2013 12:35 PM
    Please read the attached field bulletin. Even if your SN is not in the list, it may have the problem; I've seen it at multiple customers this past month.
    The following commands in order should reset the AP to bootable, however you will likely run into the same thing until you upgrade your code per the bulletin.     It may just help you from having to RMA them.
    purgeenv
    saveenv
    factory_reset
    saveenv
    Attachment(s)
  • 12.  RE: New AP105's keep rebooting
    Posted Aug 16, 2013 05:19 AM
    My new APs are indeed from the SN mentioned in the bulletin.
    I will try to upgrade the firmware of our controller and factory reset the AP afterwards.
    I will post my results later, thanks for the help!
  • 13.  RE: New AP105's keep rebooting
    Posted Aug 16, 2013 06:36 AM
    The new Access Points are working!
    • I've updated the W3400 controller to ArubaOS: 6.2.0.2.
    • Then I disconnected all the AP's from the PoE switch, causing them to restart.
    • Then the new mac adresses were showing in the controller, provisioned the AP's, everything is working!
    Thanks to all of you that contributed to this problem!
