Wired Intelligent Edge
last person joined: 11 hours ago
NTP conf - Switch 5406R zl2 J9850A
  • 1.  NTP conf - Switch 5406R zl2 J9850A
    Posted Dec 17, 2021 10:24 AM
    Dear All,
    I have a couple of Switch 5406R zl2 J9850A that are acting as my core-switches.
    They are in sync with my NTP SERVER (a Windows Server) and it's working fine.
    On this switch i have configurated all the VLAN, and all the VLAN have ad ip address assigned since this core switch is also the default gateway for all the clients, servers and device in general in every vlan.
    Is it possibile to configure this switches as NTP SERVER (acting as a relay) so that each vlan has its own NTP server for sync time pointing at its GW without need of routing?
    This is actual configuration:
    ntp unicast
    ntp server 192.168.X.Y
    ntp enable
    time daylight-time-rule western-europe
    time timezone 60
    Davide
    Davide
  • 2.  RE: NTP conf - Switch 5406R zl2 J9850A
    MVP EXPERT
    Posted Dec 17, 2021 12:44 PM
    See this post: https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=23036
    Marcel Koedijk | MVP Guru 2021 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: NTP conf - Switch 5406R zl2 J9850A
    MVP
    Posted Dec 18, 2021 03:05 AM
    Hi Davide
    No, it is not possible unfortunately.
    Shpat
