That is really old hardware and software, and I think nobody has checked if it works with modern browsers, but I would not be surprised if it doesn't. If you can find an old laptop with Windows XP, or an old Internet Explorer, you may have success, or get a Firefox portable that is 8+ years old may have some results. Did you get licenses with this controller? Many licenses are moved to newer controllers by their owners, so it may be that you don't have licenses. The command 'show license' on the CLI will give you the answer. It is no longer possible to get licenses for ArubaOS 5.
If it is a 3200, the max supported version for firmware is 6.1, if it has a memory upgrade to the 3200XM, it can run up to 6.4. From the Aruba support portal, I see that the earliest firmware you can download is 6.3. I'm not sure anymore if when upgrading from 5.x to 6.x the licenses are automatically upgraded, or if you had to manually request an upgrade which probably can't be done unless you own the licenses and have a support contract which is no longer available.
If you can make it work, you can use the wizard in the controller to get a basic configuration with an AP105, but be aware this is all unsupported and there are known vulnerabilities (like KRACK) but also in the firmware that are unpatched. Also for a personal lab/education this equipment is not representing the current state of technology. I would not spend too much time to it.
Original Message:
Sent: Feb 11, 2021 01:13 PM
Subject: Setting up 3200 GUI not displaying pages
I have just acquired a 2nd hand Aruba 3200 and am trying to set this up from scratch, I can see the monitoring page but the config and other pages are blank.
It doesn't work in Chrome, MS edge or even in Firefox portable (recommended in a previous discussion to solve this problem)
Is there an alternative browser I can use and or what special setting do I need to set?
Do I need special commands in the CLI to enable this?
Do I need a firmware upgrade, if so how do I do this through the CLI?
Does anybody have a suitable script that I can use and modify for a simple AP105 network
Sorry the wish list is so long.
JohnP
John Parsons
