Upgrading to 8.2
  • 1.  Upgrading to 8.2
    Posted Jun 06, 2019 07:46 AM
    I need to update from 6.5 to 8.2 on my Aruba 7000 and 7200 series controllers.  These are used as standalone.  Majority are used for VIA only and do not support any wireless functions.  Yes, I have two that I use for wireless, but won't be updating them right now. I have 14 devices to update. This is what I did to upgrade the first one:
    1.  Moved the new code to a test device on partition zero.
    2.  Did a write erase
    3.  CTRL X to cpboot.  Set boot partition as zero.  (bootf 0:0)
    4.  Booted device, completed initial configuration dialog.
    Enter System name [Aruba7005]:
    Enter Switch Role (standalone|md) [md]: standalone
    Enter Controller VLAN ID [1]:
    Enter Controller VLAN port [GE 0/0/0]:
    Enter Controller VLAN port mode (access|trunk) [access]:
    Enter VLAN interface IP address [172.16.0.254]:
    Enter VLAN interface subnet mask [255.255.255.0]:
    Enter IP Default gateway [none]:
    Do you wish to configure IPV6 address on vlan (yes|no) [yes]: no
    This controller is restricted, please enter country code (US|PR|GU|VI|MP|AS|FM|MH) [US]:
    You have chosen Country code US for United States (yes|no)?: yes
    Enter the controller's IANA Time zone [America/Los_Angeles]: America/New_York
    Enter Time in UTC [10:53:53]: 10:54:53
    Enter Date (MM/DD/YYYY) [6/6/2019]:
    Enter Password for admin login (up to 32 chars): ********
    Re-type Password for admin login: ********
    Current choices are:
    System name: Aruba7005
    Switch Role: standalone
    Controller VLAN id: 1
    Controller VLAN port: GE 0/0/0
    Controller VLAN port mode: access
    VLAN interface IP address: 172.16.0.254
    VLAN interface subnet mask: 255.255.255.0
    Option to configure VLAN interface IPV6 address: no
    Country code: US
    IANA Time Zone: America/New_York
    If you accept the changes the switch will restart!
    Type <ctrl-P> to go back and change answer for any question
    Do you wish to accept the changes (yes|no)yes
    Creating configuration... Done.
    System will now restart!
    5.  System booted to 8.2, but I can no loger access the device past the admin password that was set.
    My question is, why isn't the enable password set any longer during the initial configuration dialog and what is it set for if I didn't set it?  Is there is a default enable password?
    I am not worried about configurations, saving them, or using the same configuration after upgrading.  Only on how to acces the device command line after the upgrade.   Thanks.
    I have attached a log of my actions during the update.
    Attachment(s)
    txt
    aruba_8.txt   7 KB 1 version
  • 2.  RE: Upgrading to 8.2
    Posted Jun 06, 2019 08:04 AM
    Looks like you are not on ArubaOS 8.2
    Aruba Networks
    ArubaOS Version 6.5.4.12-FIPS (build 68902 / label #68902)
    Built by p4build@pr-hpn-build08 on 2019-01-29 at 21:58:14 UTC (gcc version 4.4.5)
    (c) Copyright 2019 Hewlett Packard Enterprise Development LP.
  • 3.  RE: Upgrading to 8.2
    Posted Jun 06, 2019 08:31 AM
    Nice catch.  I missed that.  Reloaded again, then CTRL X (bootf 0:0), then initial configuration dialog again, but this time, CTRL X again (bootf 0:0).  This time I am up on version 8 but .....
    Aruba Networks
    ArubaOS Version 8.2.2.5-FIPS (build 70165 / label #70165)
    Built by p4build@pr-hpn-build06 on 2019-04-20 at 01:26:51 UTC (gcc version 4.4.5)
    <<<<< Welcome to Aruba Networks - Aruba A7005-US >>>>>
    [12:20:42]:Probing for EEPROM devices [ OK ]
    [12:20:42]:Probing for real-time clock [ OK ]
    [12:20:42]:Uncompressing core image files [ OK ]
    [12:22:03]:Extracting corefs [ OK ]
    [12:22:10]:Enabling watchdog [ OK ]
    [12:22:10]:Starting device manager
    Performing eUSB Flash fast test... [ DONE ]
    [ OK ]
    [12:22:12]:Mounting flash [ OK ]
    [12:22:12]:Initializing 511MB as swap on zRam0 [ OK ]
    [12:22:14]:Turning swap ON on zRAM0 [ OK ]
    [12:22:14]:Checking system inventory [ OK ]
    [12:22:14]:Installing ancillary FS [ OK ]
    Performing integrity check on ancillary partition 1 [ FAIL : Ancillary image stored on flash is not for this release]
    [12:22:17]:Reboot Cause: User reboot (Intent:cause:register 78:86:0:2c)
    [12:22:17]:Starting syslog service [ OK ]
    [12:22:18]:Restoring the database [ OK ]
    [12:22:34]:Generating SSH keys [ OK ]
    [12:22:34]:Initializing TPM and certificates [ OK ]
    [12:23:03]:Checking for configuration upgrade [ OK ]
    [12:23:04]:rcS Done(149 sec)
    [12:23:04]:Starting OS services [ OK ]
    Starting FIPS Aruba Cryptographic KAT test
    Completed FIPS Aruba Cryptographic KAT test successfully.
    Starting auto provisioning
    Registered for NTP Sync
    Starting OpenSSL FIPS KAT test
    Completed OpenSSL FIPS KAT test successfully.
    Successfully started XLP FIPS KAT test.
    Using port gigabitethernet 0/0/3 for auto provisioning
    Initiated DHCP, awaiting DHCP response
    Auto-provisioning is in progress. It requires DHCP and Activate servers
    Choose one of the following options to override or debug auto-provisioning...
    'enable-debug' : Enable auto-provisioning debug logs
    'disable-debug' : Disable auto-provisioning debug logs
    'mini-setup' : Start mini setup dialog. Provides minimal customization and requires DHCP server
    'full-setup' : Start full setup dialog. Provides full customization
    'static-activate' : Provides customization for static or PPPOE ip assignment. Uses activate for master information
    Enter Option (partial string is acceptable):
    And I am now in a loop back to the initial configuration diaglog.
    Next steps?
  • 4.  RE: Upgrading to 8.2
    Posted Jun 06, 2019 09:22 AM
    Trying this:
    cpboot> def_part [0]
    . done
    Writing NVRAM to Flash... ffffffff8bd04110 ffffffffb6220000
    done
    cpboot> saveenv
    Saving Environment to Flash...
    Un-Protected 1 sectors
    Erasing Flash...
    . done
    Writing to Flash... done
    Protected 1 sectors
    cpboot> reset
  • 5.  RE: Upgrading to 8.2
    Posted Jun 06, 2019 09:51 AM
    Hard coding the device to boot on partition zero did not work.  I am still in a "configuration dialog" loop.  Fill out the dialog, reload and then I get asked to fill it out again.
  • 6.  RE: Upgrading to 8.2
    Posted Jun 06, 2019 10:02 AM
  • 7.  RE: Upgrading to 8.2
    Posted Jun 06, 2019 10:04 AM
    Thanks.  Instructions seem simple enough.  Will do them now and log the process/progress.
  • 8.  RE: Upgrading to 8.2
    Posted Jun 06, 2019 10:30 AM
    IT WORKED!!!!!!!!!!!
    User: admin
    Password:
    (Aruba7005) [mynode] #show ver
    ArubaOS (MODEL: Aruba7005-US), Version 8.2.2.5-FIPS
    Website: http://www.arubanetworks.com
    Compiled on 2019-04-20 at 01:26:51 UTC (build 70165) by p4build
    ROM: System Bootstrap, Version CPBoot 1.0.7.0-FIPS (build 56554)
    Built: 2016-09-22 05:27:47
    Built by: p4build@re_client_56554
    Switch uptime is 5 minutes 32 seconds
    Supervisor Card
    Processor (XLP208 Rev B1 (Secure Boot) , 500 MHz) with 3797M bytes of memory.
    32K bytes of non-volatile configuration memory.
    1920M bytes of Supervisor Card system flash.
  • 9.  RE: Upgrading to 8.2
    Posted Jun 06, 2019 10:37 AM
    FIPS mode isn't too bad.  It saves the configuration with a more secure hash and enforces encryption to FIPS values.  Password recovery is different.  If you upgrade from non FIPS to FIPS without a clearing the device you will lock yourself out since the password are encrypted differently.  Once you know the rules its very workable.
    Again, thanks for the help.
