Vlan pooling
  • 1.  Vlan pooling
    Posted Jun 10, 2016 01:14 AM
    Hi, can someone please tell me how to configure the vlan pooling. I have one controller acting as a default gateway and four switches connected to the controller. The plan is to configure one ssid for over 1000 users
  • 2.  RE: Vlan pooling
    Posted Jun 10, 2016 01:44 AM
    The basic definition of VLAN pooling is to:
    - Define two or more user VLANs within the controller
    - Put two or more of those VLANs into the Virtual AP parameter so that users are load balanced into those VLANs.
    There is nothing more to it than that.
  • 3.  RE: Vlan pooling
    Posted Jun 14, 2016 04:05 AM
    Joshua,
    Please check this Validated Reference Design document about the possibilities of using a single VLAN instead of VLAN pooling: http://community.arubanetworks.com/t5/Validated-Reference-Design/Single-VLAN-Architecture-for-WLAN/ta-p/257196
    In many cases VLAN pooling is the less desirable solution.
    Herman
