Wired Intelligent Edge
TACACS with Cisco ISE and ArubaOS-Switch
This thread has been viewed 21 times
  • 1.  TACACS with Cisco ISE and ArubaOS-Switch
    Posted Mar 20, 2019 01:40 PM
    Hello everyone,
    This guide below is how to set up TACACS with ArubaOS-Switch using Cisco ISE.
    Was missing Some Commands from the Document
    "aaa authentication login privilege-mode"
    "aaa authorization commands tacacs"
    Attachment(s)
  • 2.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    Posted Oct 02, 2019 10:38 AM
    Do you have guide for Aruba Device Management via Cisco ISE?
  • 3.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    MVP GURU
    Posted Oct 02, 2019 03:09 PM
    @capricorn80 wrote:
    Do you have guide to Aruba Deve Management via Cisco ISE?
    What do you need ?
  • 4.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    Posted Oct 02, 2019 03:13 PM
    I am trying to setup Aruba 2540 and 2930 ssh admin login via Cisco ISE using radius. Also web login if possible.
    Get Outlook for iOS
  • 5.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    MVP GURU
    Posted Oct 03, 2019 12:16 PM
    it is the same config... but replace TACACS by RADIUS ;-)
  • 6.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    Posted Oct 03, 2019 01:47 PM
    Thanks but I dont have Tacas option like like Jr_admin Profile.
    I have created Result condition as below but it doesnt work.
    Aruba: Aruba-Priv-Admin-Role = root
    Attributes Details
    Access Type = ACCESS_ACCEPT
    Aruba-Admin-Role = root
  • 7.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    MVP GURU
    Posted Oct 03, 2019 02:37 PM
    it is for Aruba Switch ?
    you need to add push like a Cisco switch shell-privilege
  • 8.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    Posted Oct 03, 2019 02:45 PM
    Yes its for Aruba Switch.
    Cisco priv works like this.
    cisco-av-pair = shell:priv-M=15
    Tried with HP radius option.
    HP-Privilege-Level = 15
    did not work.
  • 9.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    MVP GURU
    Posted Oct 04, 2019 09:02 AM
    use cisco-av-pair for HP Switch
  • 10.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    Posted Oct 04, 2019 09:29 AM
    Thanks but I am getting it.
    The Cisco AV pair for shell access is:
    I have tried it but it didnt work.
    Can you please tell me the exact format?
  • 11.  RE: TACACS with Cisco ISE and ArubaOS-Switch
  • 12.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    Posted Oct 04, 2019 10:18 AM
    No I dont see it.
    https://community.arubanetworks.com/t5/Security/ArubaOS-Admin-Authentication-with-Microsoft-NPS/td-p/433832
    This article is similar and the person is using attribute 4 with string root.
    I tried the same but it doesnt work.
  • 13.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    MVP GURU
    Posted Oct 07, 2019 01:40 PM
    It is for RADIUS and Aruba(OS) Controller...
  • 14.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    Posted Oct 07, 2019 03:03 PM
    Ok thanks.
    Any doc where I can find the exact value for Aruba switch shell?
  • 15.  RE: TACACS with Cisco ISE and ArubaOS-Switch
    Posted Oct 06, 2020 12:02 PM
    Finally I tested it again and is able to fix this.
    So I used Radius and then following settings on ISE to login.
    Network Device Profile Cisco
    Service-Type = 6
