Highlighted
Occasional Contributor I
IAP-277 wont start
Hi there,
Just received a new IAP-277, connected it to the existing Aruba AP and it attempt to start but the status light turn solid red.
Looking at the file I can see some error but I can't tell what is the issue.
Help decipehring it will be appreciated.
Thanks Dov
Accepted Solutions
Highlighted
Re: IAP-277 wont start
What is the other AP(s) that you're trying to connect this IAP-277 with?
The rest of the Instant cluster are IAP-215s? The cluster is currently running 6.5.4.8?
It looks like the problem could be insufficient power to the IAP-277:
Power Status
Item                        Value
Power Supply                : POE-AF
LLDP Power                  : 0.0W
Current Operational State   : Ethernet port 1 disabled; All radios disabled;
Charlie Clemmer
Aruba Customer Engineering
View solution in original post
All Replies
Highlighted
Power Status
Item                        Value
LLDP Power                  : 0.0W
Charlie Clemmer
Highlighted
Indeed - I changed to POE+ and everything is working as expected.  Thanks Dov
